fuel pump cam lobe - NCRS Discussion Boards
fuel pump cam lobe
  • Gary C.
    • March 1, 1998
    • 236
    fuel pump cam lobe
    Hi All
    Fuel pump replacement for a 63.
    Can someone tell me where to put the engine (ie #1 TDC) to ensure the fuel pump will be off the lobe?
    Gary
  • Larry M.
    • January 1, 1992
    • 2688
    Re: fuel pump cam lobe
    Gary:
    #1 TDC (compression stroke). You can also use a brass or nylon bolt to hold up the pushrod. Install it in place of the small bolt on the lower right side of the engine. It is a through hole, and installing a longer bolt of soft material will hold the pushrod when installing the new pump and will not cause damage. I forget the size, probably 3/8-course thread. Check to be sure.
    Some folks have successfully used a longer steel bolt, but if you do, be very careful and not tighten to much to cause damage/galling to the pushrod.
    When you finish, remove this bolt, and re-install the short bolt with some sealer (permatex #2 or equivalent) on the threads.
    Good luck. Where did you pick-up the 63??
    Larry
