54 choke - NCRS Discussion Boards
54 choke
  • Brad H.
    • August 12, 2007
    • 724
    54 choke
    Was going to remove the choke handle, cables etc and try and clean as a unit out of the car for easier pull and push, how does it come out with the nut on backside against the radio bar, or is the cable come out of the sheathing just by unhooking the carbs etc, mine didn't, tried something that worked real well, lifted each sheath up verticle then sprayed lube down them while watching it travel down entire length of sheathing, did this on all three and reassembled, mine was really stiff to pull out before and now is quite easy, must of lubed up the corrosion inside so travel of cables is cleaner. Thanks Santa, Brad.
