I am in the process of changing the wires out. PITA with all the shielding but I discovered that wires for (1 & 3) and (2 & 4) are routed between the block and motor mounts. Engine needs to be lifted from the mount to clear the boots to remove wires. Mounts were changed a couple of years ago and are replacements from NAPA.
I have looked at the AIM but it hasn't helped in this situation.
Question: is this the correct routing for the wires?
