Re: Improve oil drain back with Glyptol?
Yup, lot of oil up in an area where it doesn't belong with a high volume/pressure pump. A street big block doesn't need the kind of oil pressure that a ZL1 oil pump produces.
That ZL1 pump is designed for high RPM with oil at operating temp. It's straining it's guts out before the oil is hot, which is what most old restored Corvettes see now.
I installed a correct oil pump in my 425 HP 66 engine at overhaul 26 years ago and it has no issues. It doesn't eat distributor bushings either like it would if it had the high pressure pump.
