56-57 Convertible Top Header Latches - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I have a collection of convertible top latches for the front header for my 56 (short handle variety). My question is, I have some with ridges down the center, some with faint ridges and some without ridges at all...those are obvious re-chromed units.
    Which is correct? I was told that the latches with the ridges are correct but want to be sure so I use the appropriate latches.
    Mark
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: 56-57 Convertible Top Header Latches
    Mark, please post photos of what you have. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Roy B.
      • February 1, 1975
      • 7044
      I remember original's had a little ridge or peek to them.
      • Alan W.
        • June 21, 2009
        • 39
        Latches with ridges? This is a correct.
        • Mark P.
          • July 31, 2003
          • 407
          Gary,
          Here are a couple of pictures of what I am talking about. I know the one latch has a "bubba style" base, but just look at the main body of the latch. I think the one with ridge is correct but would like input.
          Mark
          • Gary C.
            Administrator
            • October 1, 1982
            • 17549
            Mark, refer to Alan's photo. There's an "adjustment plate" that goes on top of the latch plate base. The adjustment plate has serrations on it's back side if I recall correctly. Link to Corvette Central latches below. Gary....
            NCRS Texas Chapter
            • Steven B.
              • June 30, 1982
              • 3976
              http://www.parts123.com/parts123/yb....5Z5Z50000050x#
              Gary is correct. There are serrations on both plates to allow for adjustment and maintaining that adjustment while installed.
              Steve
              • Mark P.
                • July 31, 2003
                • 407
                Gary,
                Maybe I didn't state the question clearly enough. The pictures I posted show two different latches. One with ridge down the center of the body of the latch. The other shows no ridge. Which is correct? With the ridge or without? I have seen them both ways. I'm not asking about the adjustment plate or what is available from Corvette Central or any other reproduction vendor...just the correct main chromed body configuration.
                I appreciate the help.
                Thanks, Mark
                • David S.
                  Infrequent User
                  • May 31, 1993
                  • 24
                  Hi Mark,
                  all top latches have grooves both latch and plate .
                  there are different latches used on 1956
                  different plates also .
                  That can be turn into another discussicion.
                  It looks by your pics that someone has removed the grooves?
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Mark, great question.....I see it.....Roy said in his explanation.
                    The bottom photo clearly shows a "peak/ridge" or high spot running the full length of the main body of the hook that catches the w/s header. The photo is top view but you can barely make it out.
                    Wow I never knew that Roy. Good catch!
                    • Alan W.
                      • June 21, 2009
                      • 39
                      By looking at my 57 latches they are flat no ridge. Sorry for the misunderstanding.
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17549
                        Mark, previously answered your question that the correct handle base does have serrations in them on front side. The Corvette Central photo link saved me from having to go the shop, find a NOS set, take photos and post them. Intention was to provide a correct illustration. Gary....
                        NCRS Texas Chapter
                        • Mark P.
                          • July 31, 2003
                          • 407
                          Rich,
                          Thanks to you and Roy for noticing what I was asking. Not being familiar with the correct names for the various components, apparently some thought I was talking about the ridges on the attaching plates.
                          Anyway, from Roy's response they had a ridge and Alan says that his did not? I wonder if it was another early vs. late production issue.
                          I'm sure someone out there knows the details on this, but I guess it could be that nobody has ever brought this up before? I doubt it. Bottom line is, I just want to make sure I use the correct latches on my car.
                          Thanks for your comments and I'd appreciate more input from the 56-57 team of experts.
                          Mark
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17549
                            Rich, totally misunderstood your question. Guess I fixated when you referenced the "base". Original latches; the piece with the hook end, does have a crown in the center of it. Gary....
                            NCRS Texas Chapter
                            • Mark P.
                              • July 31, 2003
                              • 407
                              Gary,
                              Thanks for the help. From what I understand, the hook portion of the latch does have a center ridge or peak running lengthwise down the center. It appears I do have a correct set as well as some older aftermarket sets. As long as I have the right latches, I can rest easy on that portion of the project and move on to something else.
                              Thanks again,
                              Mark
