Re: Technical advice - running rich
I re-checked mine and it looks like I have used just over 1/3 of a quart in 250 miles. So I may be pushing closer to 700 miles. Whatever the case, 500 or 700 miles, or somewhere in between, should I just live with it until it starts using more? I do not want to be premature in pulling it apart and trying to remedy the problem. Clearly there is oil on the plug threads that seems like it may be a bit excessive. But it runs great. If I can lessen the heavy fuel smell I would feel very good about things.
I guess at the very least I should pull compression readings. What range should I be hoping for?
