Re: Amsoil v Mobil1
This is probably the oil that Stephen referenced:
http://www.jegs.com/i/Comp Cams/249/1590/10002/-1?CT=999
It is for break in purposes ONLY, and, of course, must be used without any ZDDP supplement. It must be removed from the crankcase after run-in, but may be run for the first couple hundred miles.
Brad Penn (former Kendall/Amalie) sells a similar product, which I have used for run-in and subsequent 100-plus miles. Zn/P concentration is not published although ARG's tech rep says it's significantly higher than the 1300/1400 concentration found in their racing oils:
