E-Brake installation Ques? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 951
    My 68 AIM looks as if the emergency brake cable (3910712 rear assembly) runs through the frame cross member.
    My photos of this area prior to disassembly shows the cable simply running under the cross member.
    1> Does the rear E-brake cable pass through the cross member in 68?
    2> how would one get the cable through the small openings if Yes to Q1?
    Pat
    68 427 / 400
    88
  • John C.
    • January 1, 2005
    • 616
    Re: E-Brake installation Ques?
    Pat
    It runs under the rear cross member.
    John
    • Patrick N.
      • March 10, 2008
      • 951
      John,
      Thanks for confirming, I went ahead and set it up that way based on my photos and the reality that there is no way to pass the parking brake assembly through any of the openings. Seems like the AIM is slightly misleading on this detail
      thanks again
      Pat
