I'm re-assembling now and the antenna doesn't look right to me. It's straight when you look at it from the side, but from the rear, it leans inboard by 5 degrees. I'm using all of the original antenna hardware but for the nut. Is this correct? Thanks.
Should the antenna be tilted inboard?
Re: Should the antenna be tilted inboard?
It has been a long time since I had my antenna in the hole, but I don't think it tilts inboard like that.Terry- Top
Hi Tom,
I just took a look at my 71.
I'm not so sure the mast base that the nut tightens against is ABSOLUTELY perpendicular to mast.
I can get the mast to be straight or tilt SLIGHTLY by turning the mast in the fittings on the rear deck and then tightening the nut.
Try that?
AlanAttached Files71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
I will check that out.
Perhaps it is a coupe/convertible "feature?" Although I can not say I have noticed that list to starboard on any body style before.
Terry- Top
I think Alan's on to something here.Hi Tom,
Try that?
I just marked where my mast was relative to the rear deck fitting it screws into, and then rotated the mast to various positions to see what effect it had. I was able straighten it up pretty significantly in a different position, although it is still SLIGHTLY tilted inboard.- Top
Here is what not to do: I have a few original big ball masts that I had chromed. When I tried to insert each one into the base they won't go in now. The layers of plating made them too large to fit!- Top
The antenna on my '72 is dead straight. But my body is tilted to the left 5 degrees!!
Ahhh, I'll just put more air in those left side tires.
- Top
Just looked at my '71 coupe #4001, build date E14. The mast is essentially straight up and down. I had it off for a paint job some 30 years ago. I also took it off in 2003 for some work, and then re-installed it myself.- Top
The antenna mast on my '72 has never been off the car, and it is straight up and down. Build date on the car is Sept. 13, 1971.Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.- Top
Hmmmm......guess GM wasn't using levels when the masts were installed. Kinda like how all those body panel seams, hoods, front
grilles, and door gaps were all perfectly aligned before they left the assembly line.- Top
