Manual trans fluid ???? - NCRS Discussion Boards
  • Michael G.
    • March 2, 2008
    • 485
    I will be changing out the fluid in my 71 manual transmission and have found only the synthetic gear oil at the dealership. It's got the GL-5 rating and is pretty pricey ($35.oo per qt.). Paragon has the GM 80-90W axle lubricant with an "EXCEEDS" GL-4 rating. I need some guidence here on what you guys use as the preferred fluid. I have read here about the new synthetics leaking past the seals. I don't beat on the car very often and put little mileage on per year. Please advise. Thanks, Mike
  • Dick W.
    • 10483
    Re: Manual trans fluid ????
    I would not go the synthetic route. As you mentioned, they will tend to leak quite a bit more. The sealing technology of the '70's left a little to be desired I would go to my local NAPA, Carquest, or store of choice and buy a reputable 80W-90, 85W-90 or what ever, as long as it meets GL-4 or better specs.
    Dick Whittington
    • Michael G.
      • March 2, 2008
      • 485
      Thanks DW. I appreciate the assistance. Mike
      • Peter M.
        • April 8, 2007
        • 570
        I know that Dick is right about C3 transmission seals not being the greatest in the world. He is also right about the fact that synthetic gear oil can seep through old or weak seals.
        HOWEVER, I can tell you that I have been using Royal Purple gear oil in my C4's Super T10 tranny for several years now and I have had no leaks at all. What's more important still is that the transmission has never been quieter or smoother. Finally, the Royal Purple gear oil has the positraction additive already in it so you do not need to add it. You will need a couple of pints at approximately $13 each to fill your transmission. http://www.royalpurple.com/gear-oil.html
        The bottom line, in my view, is that if synthetic lubricants cause your engine, transmission or differential to leak, then FIX THE LEAKS.
        FWIW
        • Jephrey S.
          • April 30, 2000
          • 64
          I tried synthetic gear oil in my M21 and promptly changed back to pure dino 80W-90 due to the leaks. If you have all new seals the synthetic might make more sense.
          As far as the pre-added posi-lubricant goes, I have not tried the Royal Purple in my differential but I did try the Castrol semi-synthetic that claimed to have the pre-added lubricant. It still took 2 bottles of the GM additive to shut up the posi complaints from the pumpkin.
          • Peter M.
            • April 8, 2007
            • 570
            All I can tell you, Jephrey, is that I have been using Royal Purple gear oil in both my tranny & differential for several years now and I have experienced no leaks and no abnormal noise. What's more, the transmission is much quieter and shifts much smoother. Also, my transmission used to pop out of second gear when coasting down a hill (probably due to worn syncronizers) and after refilling with Royal Purple it no longer pops out of gear. Of course, this is my personal experience, others may not get the same results.
            P.
            • Dick W.
              • 10483
              FWIW
              Peter, some of the earlier design sealing technologies are almost impossible to keep from leaking with conventional oil, let alone synthetic.
              Dick Whittington
                • 15610
                What Dick says. Just go to any auto parts store and by two quarts of any brand 80W-90 GL-5, and it shouldn't cost more than about three bucks a quart. That's what GM used for plant fill and recommended for service. If it works, dont fix it!
                IIRC the capcity is about 2.5 pints, but check your owners manual.
                • Michael G.
                  • March 2, 2008
                  • 485
                  Funny thing Duke, I was loking through the owners manual and the shop manual and could not find a definitive fluid capacity for the manual trans. I last changed a 4 speed's fluid back in the 70s and didn't want to rely on my fading memory. My 71 drank 1-1/2 quarts on level ground. Thanks for all reponses. Mike
                  • Dennis S.
                    • April 1, 2004
                    • 228
                    Or you could really splurge and try Lubrication Engineers Monolec. I did and paid around $13.85 per quart. After spending $800 rebuilding the M21, and considering I will probably never change it again, what the heck.
                      • 15610
                      It's a good idea to change manual transmission oil - say every 30K miles or at least every 60K.
                      Manual transmission oil usually doesn't run hot enough in normal driving to see signficant oxidation, but it does become contaminated with tiny brass particles from synchorizer wear.
                      • Alexander C.
                        • June 20, 2010
                        • 353
                        Or better yet Redline MT-90
                        • Dick W.
                          • 10483
                          In a former life, looking after the maintenance of over 2,000 vehicles, we never saw any advantage of anything but garden variety GL-4 or GL-5. We did see better shifting with 50-W motor oil in certain applications, but I would not recommend this for a Corvette
                          Dick Whittington
                          • Frank E.
                            • May 31, 1986
                            • 189
                            I just did my '66 and used Penzoil's "syncromesh" GL. On the Muncie, it takes about 40-45 oz. so buy two quarts. Cost you about $16. I was having a 3-4 slight grind and after changing the grease, no more grind
                            Frank
                            Frank
                            1966 Milano Maroon Roadster
                            2004 CE Z06
