62 Sway bar hardware finish?? - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    1962
    Approx Build May 1962
    What is the finish (black, natural, etc.) on the following items that are used to attach the sway bar: (I could not find it in the judging manual).
    1. Rear bar Link C-Bracket (outer piece)?
    2. Rear Bar Link C-Bracket Retainer (inner piece)?
    3. Spacer tube on rear link?
    4. Stabilizer Bar Bushing Bracket (attaches end of sway bar to leaf spring area)?
    5. Finish on nuts/bolts for item 4 above?
    6. Shim?
    Thank you,
    Tony
  • Anthony P.
    • June 27, 2010
    • 485
    Re: 62 Sway bar hardware finish??
    Any thoughts on this?
    Is everything semi-gloss black (except for the bolts)?
    Tony
