Need TI Pickup Coil help! - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 789
    I'm having an intermittant problem I believe is related to the TI. Box, grounds and coil are ok.
    I have checked the pickup coil and usually reads 670 ohms. I had it jump around a bit moving wires but it could have been a poor meter connection. My question is when you move the rotor, the ohms jump all over the place but go back to about 670 when I stop moving it. Is this normal or a symtom of a problem?
    Thanks for any help.
  • Philip C.
    • December 1, 1984
    • 1117
    Re: Need TI Pickup Coil help!
    Bob does your car start when you let go of the key?? (as you crank the car the engine doesnt start sometime, but starts when you let the key go) Phil 8063
    • Robert G.
      • May 31, 1990
      • 429
      I think the movement is inducing a current in the coil and affecting the ohms reading.
      • Clem Z.
        • January 1, 2006
        • 9427
        what is the problem ??
        • Bob H.
          • July 31, 2000
          • 789
          I now understand that moving the rotor will cause the ohms to jump around.
          The car starts instantly when turning the key and never cuts off.
          The problem is I seem to have an intermittant miss at idle. Sometimes the car runs fine then it sounds like a miss through the exhaust. Afterwards, pulling the plugs usually reveals they are black like it is running rich.
          Before rebuilding the engine the carbs were perfect and we replaced the ignition system entirely. That's why I leaned toward an ignition problem. I ave switched the box and coil but not the pickup coil.
          It must be that, although unproven or I have developed a carb problem during a 1 month rebuild of the engine? (I did change all the seat/valve assemblys to no avail.)
          • Clem Z.
            • January 1, 2006
            • 9427
            those TI systems either work or don't work i have seen nothing in between. make sure the wires from the pickup coil are not reversed as they have a + and - and will cause erratic running if switched.
            • Robert G.
              • May 31, 1990
              • 429
              Also check the wires to the ignition coil. I think they are connected opposite to that of a standard ignition. I've read it takes about 8000 more volts to fire if connected backwards. Don't know whether that applies to TI though.
