1969 L89 tank sticker info - NCRS Discussion Boards
  • John S.
    • May 17, 2009
    • 164
    Will the tank sticker show the L89 aluminum head option listed and if so what would it say to be correct?
    Is engine listed as 435HP and aluminum head option listed separately from each other on tank sticker?
    John
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1969 L89 tank sticker info
    Is engine listed as 435HP and aluminum head option listed separately from each other on tank sticker? ....
    John -- Here's two examples; the first taken at Knoxville 1988. You can see the 02L89AA and ALUM CYL HEAD EQUIP description. At the bottom, the L71 435hp is listed separately.
    The other two are [what's left of] a tank sticker off a friend's '68 Cordova Maroon car, also taken back in 1988. The first (middle) pic shows the 2L88AA; the other you can barely see the L HEAD EQUIP on the 2nd line down. I don't think there was much left of the bottom of the order form, but I expect the L71 would have been there.
