'66 L79 crank pulley; faking "Parkolac"
- Top
Re: '66 L79 crank pulley; faking "Parkolac"
john
The optional coating: phosphate plus spray coat with BF Goodrich A-1256-B black rubber resin base or equivalent to a 0.0004 minimum was added to the drawing on 10-18-68.
An underbake test specification that 5 drops of ketone on a rag should yield no transfer of coating was also added at that time.
john- Top
John,john
john
Do you know the date for the Parkolac coating? Presumably that pre-dates the rubber resin option.
Gary- Top
Gary,
I talked to Parker Chem (Henkel now adays).
What we need to be completely sure of the composition, is to get the old MSDS sheet for Parkolac 30. They don't have that since it was discontinued many years ago. Expecting that a base family of coatings use essentially identical ingredients, I asked about the Parkloac 2945 that was discontinued last year. It was a water diluted coating that in the notes they found references to application over black oxide. Now, if it was a wash solution over black, you would not pick up the brown color too much. It dried tack free by air. The reason it was discontinued last year was due to the base ingredient no longer being made.
Off hand I don't have a source for old MSDS sheets, we'll keep looking.- Top
