Initial advance is set at 6 degrees, giving 22 degrees of advance (initial plus centrifugal). I have experimented with different springs but only see variation in the RPM where full advance is achieved. The weights appear to be original (aged the same as top of mainshaft) and there is no bushing installed to limit centrifugal advance. I have installed a new vacuum advance canister (Napa ECH VC-1802, stamped B22), which gives a combined mechanical and vacuum advance of 39 degrees.
If I should be getting 30 degrees of centrifugal advance, what is limiting my distributor? Could it be the configuration of the weights? The distributor has been disassembled, cleaned, small parts (washers etc.) replaced and no binding or excessive wear is evident. The car seems to accelerate and run just fine.
Any ideas would be appreciated.
