Tri power carb questions - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    What is the Holley part number for the center and outer Tri power carbs? I need to order throttle plate to throttle body gaskets. My understanding is that the outer carbs are 500CFM and the center is 350CFM, is this correct?
    Also what size accelerator pump (30cc or 50cc) should be on the center carb. What size shooter nozzle was stock?
    Mike
  • William H.
    • January 11, 2010
    • 65
    Re: Tri power carb questions
