1966 Big Block Coil Springs - NCRS Discussion Boards
  • Vincent D.
    Infrequent User
    • August 31, 2005
    • 23
    The judging guide lists one number for front small block springs and one for big block springs, ie, number 3888250. I take this as the spring is the same for both AC and non AC cars...correct? The reason for asking is that I found someone who's selling a big block AC spring (and I don't have AC in my car)...and a number of vendor catalogues I checked list different springs depending on AC or not.
    Also, what's a rcommended paint and gloss level. Guide says painted black with a rust inhibitor paint?
    Vin
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 1966 Big Block Coil Springs
    Vincent,
    There are/were definitely two different front coil springs that were unique to big block for 1966. (actually, three with HD/F41) As you mentioned, one for 427 and another for 427 with air conditioning.
    The original finish was natural with a coating of rust preventative that was almost clear.
    I think the black coating that you mention first appeared a decade or so later for springs sold in service.
    • Bill M.
      • April 1, 1977
      • 1386
      Originally posted by Vincent DeSantis (44553)
      The judging guide lists one number for front small block springs and one for big block springs, ie, number 3888250. I take this as the spring is the same for both AC and non AC cars...correct? Thanks,
      Vin
      3888250 for 427 non-ac (variable rate like 327)
      3888251 for 427 with a/c (constant rate)
      • Vincent D.
        Infrequent User
        • August 31, 2005
        • 23
        Thanks guy.
        Vin
