Rear Wheel Bearing Warning Sign? - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    Re: Rear Wheel Bearing Warning Sign?
    UPDATE!!! TRAILING ARMS REMOVED! I found the outer u-joints on both half-shafts had that familiar 'grainly rough spot feeling. The 'squeak was parking brake hardware related. With everything apart, the trailing arms will be overhauled. Bushings were WAY overdue to be replaced. I think end-play on axles was ok but one spindle felt a little rough turning by hand. Thanks all
    '73 LS-4 454, owned 21 3/4 years
    • Keith L.
      • April 7, 2008
      • 378
      Thanks for the update. So many times when using the search feature on different forums you find a similar problem and never find out what the outcome was.
      • William C.
        • May 31, 1975
        • 6037
        #18
        Can't say enough about using Bairs, quick, easy, and good!
        Bill Clupper #618
        • Rich C.
          • January 1, 1994
          • 383
          #19
          Bair's was my back up choice. I'm close enough to Gary Ramaldi to drop them off to him. Saw his seminar at Carlisle, I like what I saw, seems honest and picky! Kinda like me!
