Re: Possible insight into the TDB "cam wars"
Hi Gene:
I started the EA simulation process by simulating my engine with a variety of OEM hydraulic cams, and the L79 cam quickly rose to the top. It's actually quite hard to beat the L79 cam in this particular engine. The pocket ported heads with the higher E/I ratio favor a single-pattern cam like the L79, and the larger 383 cubic inch displacement is more tolerant of the 222 degree duration than a 327 would be.
No matter what I do, the fattest torque curve keeps coming back to a cam with durations of about 220 degrees. That leaves me with just the lobe centerlines to play with. With the stock exhaust system, an LSA that is larger than the 110 degrees of most aftermarket cams and larger than the 114 of the L79 looks best in the EA simulations. I'm tempted to try this with a custom cam.
I have decided to use a roller cam in this engine because I'm tired of worrying about ZDDP in the oil and cam break-in (been-there-done-that with my current engine). I also like the benefits of the faster ramp times that roller cams can provide. The Comp Cams 280HR comes close to being a roller version of the L79 cam, so this is where I ended up with in my EA simulations.
By the way, my "cam game boy" EA simulator bears out your view that the Edelbrock 2102 offers an improvement over the OEM 929 cam. The EA simulations show a very slight reduction in low end torque, but significant imcreases in high rpm torque and power. And these simulations assume a stock Corvette exhaust system.
So, maybe my "cam game boy" isn't so bad after all.......
Hi Gene:
