Question about a balancer (harmonic dampener) - NCRS Discussion Boards
  • Joseph E.
    • March 1, 2006
    • 175
    Do any of the members have an opinion on why a 5.25 inch balancer would be on a big block Chevy motor of unknown cubic inches? The motor is in a friend's pro-street car and it seems a bit of an unusual set up. The block appears to be a GM performance block with a set of 840 heads and a Dyers 8-71 supercharger sporting two Holleys of unknown size on top of it. The crank seems to be externally balanced so I'm guessing it's a 454 or larger displacement motor. The timing tab on the timing chain cover has been moved from its original location to one lower on the cover to get it closer to the balancer. Also, the marked timing tab is no longer there, instead, the tab appears more as a pointer with no markings for advance or retard. The motor runs unvelievably strong and makes just over 800 hp. He's wondering how to time the engine with this arrangement with no one to turn to since the builder of the motor is not known. The distributor is a mechanical advance only unit as there is no vacuum canister protruding from it. I think the distributor is a Mallory unit. Any input or opinions will be passed on to my friend. Word is that this car was a former racer converted back to street use. Thanks.
    Joe (45420)
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Question about a balancer (harmonic dampener)
    Joseph,
    Wow, 5.25" is small for the stock engine.
    The Hi Perf were all larger and stabalized the crank.
    I am curious as to what others think?
    DOM
    • John G.
      • January 1, 2006
      • 85
      Apparently this is not stock engine so the balancer etal is a moot point.
      We run a 468 ci in a vega with a 5" that was installed by the machinist that balanced the engine.
      John G.
      • Loren L.
        • April 30, 1976
        • 4104
        Your only hope is the guy(s) that built the motor......
