C3 Auto to Manual Transmission Conversion - NCRS Discussion Boards
  • Brad T.
    • February 5, 2012
    • 2
    I am doing a frame up restoration on a '69 coupe. It was originally an automatic car but I would like to convert to a manual.
    Can I use the automatic transmission support cross member that bolts in (GM P/N 3987886) or do I need to install the welded cross member that welds in place to the frame (GM P/N 39878840)?
  • Joel A.
    • September 30, 1997
    • 205
    Re: C3 Auto to Manual Transmission Conversion
    You can absolutely use the auto crossmember...makes it much easier, anyway, than the welded in one of the 4 speeds. You'll need the mount bracket, and you may need to add a few holes, or do some welding, but the crossmember itself will work. Most folks go the other route...from 4 speed to auto w/overdrive, and still use the welded in crossmember.
    Joel Adams
    1974 Coupe
    1985 Coupe
    "I know the voices aren't real...but sometimes they have some really kewl ideas...."
