1967 differential plug, why the gasket? - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    I put the posi lube in my differential and put the gasket and tag on the plug thinking they would snug up and seal;
    With about 50 lbs on the plug the gasket & tag were loose so I removed the plug and checked the TPI (threads per inch) on both surfaces to make sure I didn't mix up the plug with another diff here and they were both 14 TPI.
    I brought the plug to the work bench and it is a taper plug that tightens just as pipe fittings do SO why the gasket?
    My 63 diff has straight (fine) threads and will seal with a gasket, the 74 diff had a taper plug on it with sealer.
    LIC says the gasket is for 63 to 67, that's a mistake isn't it?
    If I tighten the plug with the red tag only, the tag floats around and would not last that long.
    Whats the real story?
    DOM
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1967 differential plug, why the gasket?
    Dom -- the red posi tag is supposed to "float" ; in fact it rests on the top of the spring (unless you go over a bump). No gasket for NPT tapered thread plugs. If you have a cast ...375 rear cover it will use the taper plug, and 20 ft-lbs should seal without the shoulder of the plug touching the casting.
    Pic below is of a '63-4 ....303 cover with fine (straight) thread. I show the taper plug alongside.
    Now, just to confuse, I also show pics of a late ...303 cover with a coarse NPT thread (on my early '65). last shot is from the inside of the rear cover, showing coarse tapered threads.
    a
    • Domenic T.
      • January 29, 2010
      • 2452
      Wayne,
      Thanks for clearing up things that bugged me.
      Now that the car is going back as it was these small things like a gasket sold for NPT makes you wonder if something was changed before you got the car.
      My diff #s do match so now thats done and on to the other.
      DOM
      • Timothy B.
        • April 30, 1983
        • 5177
        Domenic
        I just had the differental plug out of my 67 and the plug had a red colored gasket. My posi tag is missing so I need to find one if anyone can help.
        I can get a picture tomorrow if you need to see the gasket.
        • Domenic T.
          • January 29, 2010
          • 2452
          Originally posted by Timothy Barbieri (6542)
          Domenic
          Tim,
          My tag came from LIC sec 02-07c (66-67) and was $8.00 .
          DOM
            Domenic
            Tim -
            No gasket on a '67 - just the NPT plug and the free-floating red plastic Posi tag.
            • Timothy B.
              • April 30, 1983
              • 5177
              Thanks for the information, I am going to pull the plug and check what Wayne posted about plug threads to see what's what.
