1966 L72 Carburetor numbers question - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hi Everyone,
    Ref. 1966 L72 Carburetor numbers
    I was wondering what the EI stamp represents that is stamped after the part number on my carburetor as I don't see any reference to it in the judging manual. Can someone help me with the meaning of the EI stamp please?
  • Scott S.
    • March 1, 1979
    • 747
    Re: 1966 L72 Carburetor numbers question
    Kurt, OH, that is a serious issue! If you are at our Ontario BBQ, I can relieve you of the problem carb.
    Scott
    • R N.
      • May 31, 2002
      • 640
      Hi Scott, Trying to re-arrange some plans Vera made a few months back as so I/we can be there. If not we will see you in Carlisle.
      • Bill M.
        • April 1, 1977
        • 1386
        from Alan Colvin: "This letter code is a customer code which is designated on late-model assembly line build sheets."
        From Alan's list, that is an EI, not E1. (edit: I see you have EI, another poster on this had E1.)
        • Joe R.
          • May 31, 2006
          • 1822
          Kurt,
          My carburetor has the same stamping. Here's a pic:
          I hope this helps.
          Joe
          • R N.
            • May 31, 2002
            • 640
            Thank you Scott, Bill & Joe for the help. Going to have it restored this winter. (It's a whistler at idle )
            • Clem Z.
              • January 1, 2006
              • 9427
              the whistle can be caused by using the wrong gasket between the carb and the manifold
              • R N.
                • May 31, 2002
                • 640
                Hi Clem,
                Thanks for the tip about the gasket. Currently I have a correct "bastardized" 069 manifold installed on the car, but someone in the past opened up the plenum under the carb and it is using a relatively thin "open" gasket rather than the correct factory style gasket with the two round holes and the larger oblong hole. I have a non-modified 069 intake and the goal is to replace the manifold while the carb is being restored over winter.
