Heat Riser - Possible lubercation - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    My heat riser squeaks a bit when operated by hand. Has anyone here tried to somehow lube it? Needless to say, what ever kind of lube is put on it, I would suspect it to burn off pretty quick.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Larry M.
    • January 1, 1992
    • 2688
    Re: Heat Riser - Possible lubercation
    Jack:
    I will occasionally use some Prelube 6 or Liquid Wrench Penetrating Oil on the heat riser. Seems to help it some. Agree, that most (or all) of it burns off when driving.
    Larry
    • Kevin G.
      • February 1, 2005
      • 1074
      Hi Jack,
      If you can find this product, it's specifically made for just your problem.
        • 15573
        Try graphite suspended in oil. Available as lock lubricant at any hardware or big box store. Lock Ease is just one brand, but there are others.
        • Jack C.
          • 1090
          Thanks guy's for the tips.
          Jack Corso
