54 - How to Fill Carb Fuel Bowls for First Start Up - NCRS Discussion Boards
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 - How to Fill Carb Fuel Bowls for First Start Up
    screw in an oil pressure gauge on the drivers side
    watch your gauge
    Disconnect your coil
    Spin the motor over while running the drill.....
    that way you get oil thru all the passages....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • John L.
      • February 1, 2005
      • 207
      Thanks Chris,
      I do have a gauge hooked up to the little start up panel that I could have someone watching while I spin the pump with the drill. Just looking for some indication of a pressure reading correct.
      • Chris S.
        • January 1, 2000
        • 1064
        #18
        yes and turn over the motor at the same time
        • Dale M.
          • December 27, 2007
          • 386
          #19
          watch your gauge
          I am not sure you want to spinn the motor as this will turn the camshaft. There are a lot of recommendations to get the motor started quickly to get oil to the cam ASAP, expeciall with flat tappet cams. Spinning the motor may be OK, if you have oil flowing first. I have not quite thought through the spinning as it relates to getting oil through all of the passages. Other thoughts?
          • Chris S.
            • January 1, 2000
            • 1064
            #20
            these motors have such low valve spring pressure - no way your going to wipe a cam in one of these low compression engines....
            by turning the motor over - the holes in the crank holes and bearing holes will allow oil to flow through out all the oil passages....
            Many professional builders do the exact same thing....
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12695
              #21
              I though when building an engine some special thick oil was used on all the iron on iron part surfaces. Why is pre-running the oil pump then needed?
              regards,
              Rob.
              Rob.
              NCRS Software Developer
              • Chris S.
                • January 1, 2000
                • 1064
                #22
                one - it primes the oil pump - so at start up - you have instant oil pressure
                two - it lubricates all the moving parts prior to start up
                good insurance....
