Went for a run last night and filled up. After stopping we smelled gas. Turns out that the check valve on the drivers side of the tank that leads to the charcoal canister is leaking. I took it out and got a couple of pieces of hose, put it in water and blew. I quikly found the leak. It was on the seem on the bottom. Has anyone had any had any luck re-sealing these valves???
I do not relish the idea of fuel dripping on the muffler, fire is bad! Thanks!!
