I'm trying to make sense of the service part # changes throughout this early Mark IV period and correlate to the physical appearance of the housing, and how it relates to the lower annulus oil groove.
Picture is of two cast iron distrib housings: the one on the top is (supposedly, per eBay seller) removed 20 years ago from a '66 Chevelle 396/325hp w/manual trans. Band 1111109 dated 5_G_7 (July 7th 1965). Must'a been one real early '66 Chevelle, as the 5 assembly plants producing '65 Chevelles worked until early to mid-August. This distrib was probably installed in a 3855961 cast #, 2-bolt block.
The one shown on the bottom is from a '66 L72 Corvette (VIN unknown) with band 1111093 dated 5_J_20 (Sept 20th 1965).
Focusing on the Corvette housing, which is our main interest here, the only difference I can see is the tach drive. The Chev parts catalogs P&A30 show the following listings under the group 2.362 "housing", and the service parts history of the same.
For the '093' distrib, the part # in the July '65 revision of the parts book lists #1965974, but by Oct'65 (in the first issue of the '66 P&A30) they're calling this '974' part # the 1st design, for the '65 396 Corvette alone, and adding (2nd design implied ?) # 1966654 applicable (again) to '65-6 Corvette distrib's 093, as well as '66 Corvette distrib's 1111141 & 142, the latter two for '66 L36 without/with K66.
The July '69 parts history shows # 1965974 was replaced in service by 1966654 on 11-66, then switches back again to 1965974 on 5-68 (huh ?).
The Jan '69 P&A30 says # 1965974 for all BB Corvettes; no caveat about installing in the '65-6 with grooved rear cam:
1st line for '65-7: 1093, 1141, 1142, 1240 1247 1248 1258 (ie. for distrib's originally w/partially filled oil annulus, as shown in my pic ?)
2nd line for '68-9: 1111293/1294/1295/1296/1111926/1927/1928/1950 (ie. for TFP that never had, nor needed, a partially filled oil annulus ?)
Any insights welcome.
