70 L46 4 speed Transmission Removal and Clutch Replacement
Re: 70 L46 4 speed Transmission Removal and Clutch Replacement
HI Guys.
I just wanted to get back to everyone.
I just today finally pulled the transmission. I know, it has been a year. It was not bad at all on my back. I am sure getting it back in will be a little tougher.
I purchased the harbor freight jack but did not need it to pull the trans. Should be a big help getting it back in.
Thanks for all the great advice.
Bill- Top
Just one more update and a quick question.
M20 has been out and rebuilt. New balanced flywheel, clutch, and yoke. Found a lot of issues when I finally took things apart all of which have been corrected including a non magnetic pilot bushing.
Transmission has been reinstalled and frankly that part went a little smoother than expected laying on my back.
I cannot thank everyone enough for all the great advice.
Now for the question.
Should I install the shifter bracket first and then the shifter or can I install the shifter on to the bracket and then install the assembly? The two bolts on the bracket would sure be easier to do while out on the bench. I removed the shifter and then the bracket when I disassembled. Back then I was just planning a simple shifter rebuild. Project creep
Bill- Top
Bill,
I've found it hard enough with the shifter off the bracket. I can't imagine you can do it with them already assembled together.Vice-Chairman (West), Michigan Chapter NCRS
Don't feel too bad...I nursed alone a flakey clutch on a C5 Z06 for 6 years. A couple years ago I took the whole labor day weekend + one day to get it done on jack stands. With it you must remove EVERYTHING behind the Torque Tube, Trans Axle and it is HEAVY.
Mike- Top
I bet it was heavy.Don't feel too bad...I nursed alone a flakey clutch on a C5 Z06 for 6 years. A couple years ago I took the whole labor day weekend + one day to get it done on jack stands. With it you must remove EVERYTHING behind the Torque Tube, Trans Axle and it is HEAVY.
Mike
I can laugh now but when I pulled the transmission I was just a little too proud not realizing I did not have quite enough room to get the trans off my chest. I was laying under the the car and got stuck with the M20 on my chest and the reverse light bracket digging in to me. I finally was able to shimmy and get the transmission off my chest but it sure was close.
I actually had a pretty easy time getting it back in all things considered.
Cannot wait to drive without all the vibration and a transmission that will shift as it was intended.
Bill- Top
