65 Turn signal switch - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    My TS switch upper plate broke and I replaced the upper plastic plate on my 65 standard srteering column with a replacement plastic OEM plate and before I screwed the replacement upper plastic cam to the lower plastic piece, I noticed that one brass contact strip was distorted. I straightened it a little and put together. Getting the sheet metal Phillips head screw into the new plastic to fasten the upper and lower plates together, with the switch still in the column, was a bear. Assembled the switch but signals still not working right. Does anyone sell the replacement brass contact strips or must I search for an old used switch? I know that guys have straightened these but they are quite delicate. I've heard so many horror stories about the repro switches that I hesitate buying a replacement.
    The steering shaft index mark was not lined up with the wheel hub index mark which may have caused misalignment of the the plastic cancelling cam with the upper switch plate which may have caused my problem to begin with.
    Dave K.
  • Wayne P.
    • January 23, 2008
    • 444
    Re: 65 Turn signal switch
    Dave I just replaced my turn signal switch in my 64. I took the column out first. Good time to inspect and I re lubed lower bearing. re painted . I bought from Brian at Bairs . installed works great. I think the column has to come out because I couldn't get the wire assembly past the bracket that attaches to cluster. Good luck. Might check Bairs as well for replacement strips . or contact me and I will give you my old ones.http://www.bairs.com/search.asp part DS191
