Need some help with identifing the dimensions for the round holes on the top of a late '66 radiator. I purchased a new radiator from DeWitt's and it has the square and rectangular holes on the top of it, but didn't have the 3 or 4 round holes. I need to know the size of the holes and their location relative to one of the square or rectangular holes. Thanks for you help!
Late '66 Radiator
Re: Late '66 Radiator
Need some help with identifying the dimensions for the round holes on the top of a late '66 radiator. I purchased a new radiator from DeWitt and it has the square and rectangular holes on the top of it, but didn't have the 3 or 4 round holes. I need to know the size of the holes and their location relative to one of the square or rectangular holes. Thanks for you help!- Top
Thanks Craig. I purchased the radiator sometime ago and I supplied DeWitts with my build date, so I thought I had a correct part. Unfortunately it appears it needs this modification and it is installed in the car, so it looks like I will need to do it myself. So if you can provide me with the dimensions I need that would be very helpful. Do you know if these holes were on the bottom side of the radiator as well? Thanks for your help!Bob Puls, 30633- Top
Thanks Craig. I purchased the radiator sometime ago and I supplied DeWitts with my build date, so I thought I had a correct part. Unfortunately it appears it needs this modification and it is installed in the car, so it looks like I will need to do it myself. So if you can provide me with the dimensions I need that would be very helpful. Do you know if these holes were on the bottom side of the radiator as well? Thanks for your help!- Top
Craig, Could you please supply me with a copy of the radiator top plate hole dimensions; I am in the process of restoring my early 1967 radiator? Thanks in advance, Kieran (11373)- Top
- Top
