1954 6-Volt to 12-Volt Conversion Requirements - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    ITEMS NOT REQUIRING CHANGING BUT WORK FOR 6 OR 12 VOLT SYSTEMS
    Courtesy light switches
    Brake light switch
    Neutral safety switch (on transmission)
    Turn signal switch (in column)
    Ignition switch
    Dimmer switch
    Wiring harness
    Oil pressure gauge - mechanical
    Amp meter
    Starter solenoid
    Points and condenser
    ITEMS REQUIRING CONVERSION OR SPECIFIC 12 VOLT COMPONENTS
    Generator conversion
    Voltage regulator
    Ignition coil
    Parking brake flasher (tung sol 642?)
    Lamps
    Clock conversion
    Cigarette lighter
    Positive battery cable
    2) Horns and Horn Relay - If keeping with the 6 volt horns can also keep the 6 volt relay since horn is only for short bursts and not a continuous current draw. Should a 12 volt relay be installed?
    3) Heater Fan and Switch - If changing to a 12 volt fan motor will there also be the need to change the resistor on the fan switch?
