Correct A/C Manifold Port Caps - NCRS Discussion Boards
  • Christopher K.
    • September 10, 2007
    • 311
    Can anyone tell me which cap is correct for the air conditioning manifold connections on my 1972?
    The larger one is a repro and the smaller is an old original from an unspecified vehicle.
    Thanks for the help,
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
  • Bob D.
    NCRS Shipping Data Report Manager
    • April 30, 1996
    • 785
    Re: Correct A/C Manifold Port Caps
    Chris
    The smaller of the two caps appears to be the correct manifold cap. It is very similar to those on my '71 which has the orignal caps on it.
    Bob
    • William C.
      • May 31, 1975
      • 6037
      As I recall, my '72 had the round head rather than the flat head, easy to pick out, but been a few years, I was second owner of low mileage car.
      Bill Clupper #618
        • 15573
        If I had a `968 to 1972 Corvette with C60 I would like the one in the last picture.
        • Dick W.
          • 10483
          Picture #4. Cadmium plated
          Dick Whittington
          • Christopher K.
            • 311
            Thanks very much everyone, I appreciate the comments.
            Chris
              • 15573
              I would argue it should be tin, but without a metallurgical test we will never know.
              • Dick W.
                • 10483
                Picky, picky, picky Ever which one was cheaper I am sure.
                Dick Whittington
                  • 15573
                  Amen brother!
                  • Kurt G.
                    • April 30, 2005
                    • 343
                    My early '72 has a rounded top, cad plated cap.
                    Kurt Geis
                    Chairman, Midway USA Chapter
                    Targa Blue 1972, Top Flight and Duntov Award, 2014
                    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                    Arctic White 2013 60th Anniv Special Edition Conv.
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Agree, Dick -- without chem analysis . This might have been discussed in years past.
                      Here's a service AC manifold / muffler I have -- believe it is the 1968 part # as that was all that was available from the General in the early '90s. It's NOS, in the sense that it's been installed (for appearance) on a compressor, but never seen Freon .
                      The plating is (now) even darker than I remember a decade ago. I get the impression you could rub it off entirely with little effort.
                      Close-up is of what I think is a Weatherhead stamping (going by the hex and the feather tail of an arrow) -- any thoughts ?
                      Also I can now make out the hex stamping with the 'W' in a vertical row on the face of the cap in the middle of the first pic.
                      • William C.
                        • May 31, 1975
                        • 6037
                        Mine was a late car, same result, domed top probably cad in that era, conversion away from cad started about '74 in GM as I reacll. We spent a TON converting plating lines, installing new lines etc.
                        Bill Clupper #618
                        • Dick W.
                          • 10483
                          I believe Weatherhead was the OEM supplier. When I first started in the restoration business, I was able to purchase brass caps from Weatherhead. If only I had known, I would have purchased 1,000 while they were still available. You know, the old woulda, coulda, shoulda routine
                          Dick Whittington
                          • Christopher K.
                            • 311
                            Great pics Wayne, thanks!
                            Chris
                            • Peter L.
                              • May 31, 1983
                              • 1930
                              Wayne - I've found the hex-nut Schrader valve caps with the WeatherHead logo, and both of the configurations of the caps that started out this thread on various Chev & other GM
                              AC manifolds on A6 Frigidaire compressors. Personally, I think you can "pick your poison" when it comes to which one was the cap "du jour" for that day, production run, or year; but trying to figure out what was used after 40-50 years is what make this hobby fun. Pete
