I don't have a tool to hold the flywheel stationary while I tighten the balancer safety bolt, so I built a tool out a aluminum pipe to hold the balancer in place while I tighten the bolt. It looks look and in theory, it should work. I will let you know if it works or not in a couple of days when the used correct balancer arrives.
283 Harmonic Balancer Holder Tool
Re: 283 Harmonic Balancer Holder Tool
Looks good and should work fine.I don't have a tool to hold the flywheel stationary while I tighten the balancer safety bolt, so I built a tool out a aluminum pipe to hold the balancer in place while I tighten the bolt. It looks look and in theory, it should work. I will let you know if it works or not in a couple of days when the used correct balancer arrives.Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
