1992-96 Air Dam Instruction Sheet - NCRS Discussion Boards
  • Pat F.
    • April 1, 1981
    • 852
    Looking for a back side of Instruction Sheet for the installation of the air dam and front license plate and filler panel.
    I have a good front page, but the opposite side I have is very fuzzy.
    Also anyone who installed his rear license plate or front license plate on a 1992-96 Corvette, I like to hear from you as to the source of the mounting screws. Also anything else related to the USA-1 Black Plastic Plate which is shown as a Bracket in the GM Parts Manual. Were the screws that held this USA-1 plate removed and utilized for the mounting of the rear state license plate.
    You can pm me if you want or contact me through fulassoc@comcast.net
    PAT, Central New Jersey and Florida Chapters
  • Pat M.
    • April 1, 2006
    • 1575
    Re: 1992-96 Air Dam Instruction Sheet
    Pat, if I understand, you want to see the opposite side of the page you pictured, which is the first page of that section, which I've attached. Just in case you wanted the seperate page opposite the page you pictured I attached it as well. Let me know if they're clear enough for you.
    Both my front and rear license plates came from my dealer attached with small torx head screws. Rear screws (4) have captive washers, front screws (2) do not. And yes I used the hardware already attached to the rear plate to secure the state license plate.
    • Pat F.
      • April 1, 1981
      • 852
      Pat, thanks for your response, however what I am looking for is the back side of the installation instructions for the air dam.
      The air dam was in a package put inside the Corvette at the factory and installed by the dealer. I guess after installation, since the instructions were not needed, they were trashed. That is why I am having a hard time getting this copy.
      As for the mounting of the rear/and or the front license plate (not the filler panel) there has been no consistency. Again, done at the dealer.
      I have found a number of different screws, sometimes not enough screws, wrong kind, missing washers, you name it.
      This is a very small judging item, but just want to get it straight.
      Thanks again for your input.
      • Pat M.
        • April 1, 2006
        • 1575
        Sorry Pat, the dealer instruction sheet exploded view is nearly identical to the SM exploded view, and after only glancing at your picture I just assumed you were asking about the latter. And I don't have the former.
        I also thought you meant the front filler panel when you asked about the "front license plate." My front filler plate and rear USA-1 plate came from my dealer with the screws I described.
        Regards, Pat
        • Pat F.
          • April 1, 1981
          • 852
          No problem, thanks for your time.
