54 rear trunk lid harness Question - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    It doesnt look like the connectors to the licience lights will pass thru the holes in the lid. I dont see how the wires and connectors will pass. Do the connectors need to come off? Thanks as always!!
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 54 rear trunk lid harness Question
    remove the plastic connectors first. good luck.mike
    • Chris S.
      • January 1, 2000
      • 1064
      I did not have a problem
      Fish some metal wire from hole to hole with the grommets removed.
      tape the wiring harness to the wire tightly and the connector offset from one another - and pull thru.....
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 499
        Thanks again Chris!...........a different question..........the brown wire for the horn button that needs to get soldered to the steerung column bearing, that new bearing needs to come out yes?
        • Chris S.
          • January 1, 2000
          • 1064
          No the brown wire is already attached to the bearing
          fish a wire up for the horn and turn signal wiring
          Pull thru
          Install the bearing flush
          make sure to remove the paint from the end of the column
