C1 Mirror repair (outside) - NCRS Discussion Boards
  • Philip P.
    • February 28, 2011
    • 558
    Does anyone know a graceful was of removing the mirror from the mount?
    Phil
  • Chris S.
    • January 1, 2000
    • 1064
    Re: C1 Mirror repair (outside)
    the y- 50 mirror ?
    if the allen bolt is seized - removed the interior door trim and remove the two nuts from the bottom - (hopefully they wont spin) and remove the whole mirro from the car.
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Philip P.
      • February 28, 2011
      • 558
      Yes it is a Y50, I guess I was not real clear, how does the mirror itself come off the base. I would like (if possible) to remove the mirror to have the base rechromed. I know it can be sent off but would like to do it locally. I am assuming (trouble) the the back of the mirror is stainless. Is the swivel pressed in or threaded.
      Thanks again
      Phil
      • Gary C.
        Administrator
        • October 1, 1982
        • 17549
        Phil,
        My friend that restored mirrors, who has since passed away taught me the only way to disassemble an a Guide Y50 outside mirror is to break the glass.
        The back is chrome not stainless on 1957 Guide Y50 mirrors. Sent my 1957 mirrors to Paul's Chrome to be redone.
        You might check with Joyce Burrell who restores mirrors and advertises in the Driveline.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Chris S.
          • January 1, 2000
          • 1064
          There is an allen bolt on the back side - lower - it attaches the mirror to the base
          Remove the allen bolt and the mirror comes off its base
          If you need to restore the mirror
          Send it to Joyce
          She will prob be able to exchange it
          She has Y-50's in stock
          I have worked with her several times
          Great lady !
          • Joe M.
            • April 30, 1990
            • 1338
            Phillip, I tried to remove the mirror from the ball on my original Y-50 and the result was a destroyed original mirror. I made a fork-type instrument to wedge between the ball and the back of the mirror; thinking that I could pull the mirror assembly off of the ball. The back of the mirror is very thin metal and I crushed the back plate. Joyce Burrell is the only expensive option I know of. She does not offer a discount when you send your mirror in for restoration. When she rechromes the back of the mirror, sometimes the chrome is thick and fills in the Guide Y-50 and sometimes it does not. Her prices depend on the degree of chrome deposited into the Guide y-50; at least when she sells them at NCRS events.
            • Dennis C.
              • June 30, 2002
              • 884
              When I did my 61 mirror I did as much as I could myself. I removed the glass and mirror back plate (the swivel was loose, so I was going to have to repair that anyway). I then sent the bare frame to Paul's to have it chromed. He recommended having the engraving on the back redone, because the chrome process would have filled in most of the engraving.
              When the mirror came back, Paul's had pressed out the ball from the base without any damage. I reassembled the mirror and then sent it out to Joyce to have the proper glass installed.
              Dennis
              • Philip P.
                • February 28, 2011
                • 558
                Thanks all for the information, it does appear that the ball stud can be removed I guess it is figuring out how, I will post the results from my attempt
                Phil.
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17549
                  Phil,
                  Soak the stud several days with Kroil Oil www.kanolabs.com
                  IIRC what I did - after several days of soaking with Kroil Oil, placed a small screwdriver or punch on the ball head with the base clamped down and gently tapped around the ball head until it came out.
                  Gary
                  NCRS Texas Chapter
                  • Philip P.
                    • February 28, 2011
                    • 558
                    Gary, one last question is the ball head grooved into the base or is just a friction fit, not that is matters just was wondering.
                    Thanks for the information
                    Phil
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17549
                      Phil,
                      The Guide Y50 mirrors I did had straight splines (notched/grooves).
                      Gary
                      NCRS Texas Chapter
                      • Philip P.
                        • February 28, 2011
                        • 558
                        Gary thanks never even got off the site great service. I'll post the outcome (good or bad)when I start..
                        Phil
                        • Rod K.
                          • 441
                          Get two pieces of flat stock 1 to 1-1/2 inches wide and about 1/8-3/16 thick. Total thickness must fit in the gap between the ball and the face of the base where the stud is pressed in. Slot both pieces to fit snugly around neck of the stud (yes, it's a straight spline). Bend the end of one piece slightly, 20-30*, just past the end of your slot. Slide both pieces over the neck of the stud, flat piece against the base and bent piece under the ball with the free ends apart and use the bent piece to lever against the flat one and pry the stud out. Works like a charm, I've done several this way.
                          • Roger W.
                            • January 29, 2008
                            • 564
                            Rod, Do you have any photos that you can post? Sorry, I'm a little confused about the bent end of the flat stock.
                            • Philip P.
                              • February 28, 2011
                              • 558
                              Rod, that looks like a good way, I imagine once it gets moving either with the tap method or prying up as you have done it comes out pretty easily. At least I have a couple of ideas to try.
                              Phil
