My Saddle Tan '63 coupe has been back from the paint shop for over a year and I've been slowly getting it going in between other projects. I decided yesterday to crank it for the first time in over 30 years. I've owned this one for over 25 and bought it in boxes WITH the original drivetrain (340 horse) but have been slow getting it finished. So I bumped the starter over a number of times to get the valves set, and set the timing with the timing light but without fuel so it couldn't crank and then put fuel to it. Cranked it for a few seconds and it was running rough, so shut it back off. (clown at the bodyshop apparently thought crossing a few plug wires would be cute). Run back through firing order, which of course involved taking lower shielding off both sides. When I cranked it again after about 2 or 3 seconds in lunged forward punching one of my '67's which was parked directly in front. The car didn't even have a shifter installed yet, so I knew it didn't jump in gear. I pulled the transmission (early '63 car with T10) and 3rd gear is stuck tight on the main shaft. I haven't tried to press it apart yet to see how bad the transmission damage is, but in all these years of messin' with cars I have never heard of a manual transmission car galling a gear on the output shaft. Except for being manually pushed around my garage some and some at the bodyshop too, the transmission couldn't have over several hundred revolutions total in it. The 90 wt oil hasn't even had a chance to wash the grease out of the needles in the rear of the input shaft yet. Anybody else ever seen this happen?
The good news is it didn't hurt the '67 even though the rear bumpers are off of it, but the bad news is it cracked either the surround or has a nasty paint crack to the left of the right headlight. Paintwork again for sure, hopefully no glass work.
