In an earlier post, I was inquiring about vacuum and idle and then this gas smell question got in the way, so a new thread is born.
I have read the archives and searched on the forum and it seems that the JB Weld on my fuel vapor separator has deteriorate enough that I can blow through the separator (what a pain to remove with the tank installed) and get a little air out. The JB Weld repair is still "mostly" intact but mostly doesn't count with gas fumes in the garage, both for safety reasons as well as my wife's complaining. I will be ordering a new one but one of the things I wanted to do was to replace the hoses since they are almost 43 years old. For those that have replaced the hose and/or separator, is the easiest way to get at them to drop the tank? I only have about 3-4 gallons in the tank and, now that the spare tire tub is off, this might be the time to drop the tank, replace the hoses and then re-install the tank, hoses, and vapor separator all at once.
So, has anyone done this? Can one drop the tank with the exhaust, rear bumpers and everything else in place?
