Pop-up when opening a thread - NCRS Discussion Boards
    • 11608
    When I click on a thread with new replies to open it, there is a white pop-up (pop-behind?) that appears behind the NCRS window, expands, and then disappears. It then recurs if I go back to the main DB page. If I knew a way to capture it to show you, I would, but trying to do a screen capture is not working. It is consistent and has been happening for quite a while.
    Does any Admin know what is doing this? I have it with no other forums or websites.
    Patrick
  • John W.
    Administrator
    • November 1, 1974
    • 5079
    Re: Pop-up when opening a thread
    Patrick,
    I can't duplicate the pop under you describe.
    Administrator
    www.ncrs.org
      • 11608
      It happens virtually every time I change a page on this site.
      Of note, only seems to happen at home when on Firefox. It does not happen with Chrome.
      • Jack M.
        • March 1, 1991
        • 1138
        I see this on the TDB occasionally (via Firefox). Since I have some popup blockers... I simply guessed they were just doing their job.
          • 15573
          I am using Firefox at home and don't see this, and I too have pop-up blockers installed.. At work we use IE and no sign of this either.
          • John W.
            Administrator
            • November 1, 1974
            • 5079
            It may be do to the combination of Firefox with a particular pop up blocker. You might try turning off the pop up blocker to see if that stops if from happening. You can then see if you can find a different pop up blocker to use.
            Administrator
            www.ncrs.org
            • Jack M.
              • March 1, 1991
              • 1138
              Itz a non-issue for me... just confirming what Patrick was observing.
