12 hour "Edit Window" not long enough - NCRS Discussion Boards
  • Dave P.
    • June 30, 1991
    • 184
    1
    I think the time limit should remain 12 hours.
    0%
    1
    I think the time limit should be extended for several days.
    0%
    0
    The poll is expired.
  • John W.
    Administrator
    • November 1, 1974
    • 5079
    Re: 12 hour "Edit Window" not long enough
    Originally posted by Dave Perry (19643)
    Sometimes as a thread 'develops', one realizes that an earlier response needs modification, clarification, or even deletion.
    12 hours is just not long enough. It seems the 'active life' of a technical thread is only a few days long. One should be able to modify their 'thinking' or position during that time.
    Or, what if you make a typo on a part number, but don't catch it until the next day? Too bad, the erroneous number is now in the archive. Sure, make a correction in an additional post, but that just adds to clutter and confusion.
    On another forum I participate in, our V-Bulletin has a 7 day edit window. That seems to be enough.
    Dave this is configurable. The main reason that there is a limit is to prevent people from changing their post after someone else has posted a response. If you answer my question, I could then go back and change the question and make you look bad. With the Members Only board like this I think that would be rare but could cause trouble.
    What do others think about extending the length of time that a message can be edited by the poster?
    Administrator
    www.ncrs.org
