Heinous crimes - NCRS Discussion Boards
Heinous crimes
  • Loren L.
    • April 30, 1976
    • 4104
    Heinous crimes
    I went to a question about the '63 Air cleaner element. I got a board that said: You may NOT post new threads; you may NOT post replies; you may NOT post atachments; you may NOT edit your posts...
    And yet, if I ignore all of the above, I am presented with board and the opportunity.... will it appear or not....and if the answer is NOT, I propose a revolt....we try to convince former officers like Bill Clupper, now retired, to run for the Board, and a few partners and...........
  • Loren L.
    • April 30, 1976
    • 4104
    Re: Heinous crimes
    Would someone please try to explain the NOT advisory IF IT IS NOT VALID????
    • Stuart F.
      • August 31, 1996
      • 4676
      Re: Heinous crimes
      I found that once I registered under my name and member number using one "Screen Name", I could not get on under my second screen name. Could this be your problem? I too got all kinds of messages and warnings, etc.
      Stu Fox
      • Dick W.
        • 10483
        Re: Heinous crimes
        Sounds like that somehow you logged in as a visitor.
        Dick Whittington
        • Gary C.
          Administrator
          • October 1, 1982
          • 17549
          Re: Heinous crimes
          Loren, as Dick said you only get the "you don't have the permission to post" if you're not a member. Just look at the "Welcome" message on the upper right hand side to see if it says Welcome Loren. If it doesn't you're not logged on. Gary....
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12695
            Re: Heinous crimes
            Loren,
            I'll give you a call later today to see if we can figure out what is going on at your computer.
            regards,
            Rob.
            Rob.
            NCRS Software Developer
