ok I give up - how do I search for "third arm" - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1114
    ok I give up - how do I search for "third arm"? both third and arm are too short or simple, and even in quotes it won't work. i tried stars, etc.
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12695
    Re: ok I give up - how do I search for "third arm"
    those words are too common and can't be used since they return too many search results...
    Rob.
    NCRS Software Developer
    • Gary C.
      Administrator
      • October 1, 1982
      • 17549
      Ian,
      Recommend you read the FAQ on Search. Rich M. did a lot of test searches and his uses of wild cards, etc. are included.
      Searching for something like "third arm" will take a lot of trial and error to refine the search criteria using Rich M.'s test results of the wild cards, etc.
      Also consider that "Third Arm" may not have been used to describe a front suspension part.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Harry S.
        • July 31, 2002
        • 5258
        I get 21 hits use the search argument ------> "*third arm*"
        • Ian G.
          • September 3, 2007
          • 1114
          no "third arm" is there. It's the part right under the front grill attaching to the tie rod ends (as I'm sure you know). I have seen it while searching on paint info etc, but can't search on it specifically I've read the search info and I haven't found any way to get third arm in a search. why are we limiting the search in this way? I'd assume you could modify the exclusion word list to remove "arm" and "third" from the list... I would just use google to search the site for it, but...
          • Gary C.
            Administrator
            • October 1, 1982
            • 17549
            Ian,
            As previously questioned "is third arm a good search term".
            Suggest you try searching on Pitman.
            Did you read the FAQ's on Search yet? Searches are trial and error to narrow the results.
            The search function is inherent to the TDB software and it's not something that can be modified.
            Gary
            NCRS Texas Chapter
            • Ian G.
              • September 3, 2007
              • 1114
              Ok cool thanks! I didn't try that... I tried *third and *arm and arm* and third*. We are using vBulletin forums so per their site the admins should be able to modify these minimum terms and other settings to be more user friendly. But that might impact the bandwidth of the site. So...
              • Gary C.
                Administrator
                • October 1, 1982
                • 17549
                Ian,
                The vBulletin search function was modified to include "boolean" search functionality. That's all we can and are going to do.
                If you can write code and want to re-write the search functionality, contact John Waggoner and let him know. We're always open to volunteers.
                Gary
                NCRS Texas Chapter
                • Ian G.
                  • September 3, 2007
                  • 1114
                  Sadly, I'm not a coder, or I'd be happy to assist. I just work in the business on the technical end. If there's anything shy of coding you need help with, let me know.
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17549
                    you're added to the potential "volunteer" list - thanks
                    NCRS Texas Chapter
