I am replacing all brake and master cylinder lines. I want to use the original steel type. Some suppliers color code the connectors on the master cylinder to proportioning valve.(I don't think this is correct) Some do not have accurate, original bends in the lines, especially the line from the proportioning valve to the front left block, (which is held to the front to rear line with a small clip). I am looking for one supplier to get all my lines from, with all the correct, original bends, and plated connectors. (I am reposting this messasge as I deleted it by mistake)
