C2 Steering - NCRS Discussion Boards
C2 Steering
  • Steve Shanks
    C2 Steering
    Just discovered on the steering shaft (engine side) a "cream colored" plastic collar male/female unit and then a metal flange. The collar has thread and looks like there is a spring on the shaft and under the plastic collar...It looks as if it's loose........How should it be on?
  • Bryan L.
    • June 30, 1998
    • 397
    Re: C2 Steering
    on the early 67 steering columns through about January (not sure), an O-clip was used. On the second design columns a different type was used that was similar if not identical to the clamps on the tie rod sleeves. Long Island and Dr. Rebuild will have the one you need.
    BL
