I recently bought a T10 on eBay that I thought might prove to be a "numbers match" for my late Jan built 62. The main case date is L 21 61, and the tail case 11-19-61. So far, so good. HOWEVER, once the trans arrived, the main case turns out to be cast iron with aluminum paint. So much for that idea. I didn't pay a lot for the tranny, so I'll probably keep it around for a spare. I would like to know what it is supposed to fit. It looks like it is the right configuration, but I'm not sure. The main case is marked "T10 1 B, WG DIV"
The tail case is marked "T 10 7B". It does NOT have the "bowtie" logo. What have I got, and will it fit the 62, shifter bolt up ok, etc.? I currently have another iron case T10 in the car that I haven't bothered to check the dates on. It was supposedly rebuilt just before I bought the car, but if I shift smartly into high gear, it will scrape a little. Never had a transmission that would scrape going into fourth, usually the second gear syncro got all the wear. A little bumfuzzled about that one. Anyway, what is this thing? Thanks.
