Windshield replacement for 1957 - NCRS Discussion Boards
  • John S.
    • January 1, 1998
    • 81
    Does anyone have any suggestions as to how to remove the stainless around the windshield on a 57. I am painting the car and then replacing the windshield. I am having difficulty. HELP!!!
  • Roy Braatz
    Re: Windshield replacement for 1957
    You have to remove the windshield from the car ,then remove the side post. The stainless it self covers the top and bottom frame work.I would not suggest removing them with the windhield on the car, no way.
    • John M.
      • January 1, 1999
      • 1553
      Roy is exactly right! that is how many of the windshield posts with broken tabs got that way. There were too many glass installers who were too lazy to remove the entire windshield. I talked to an old glass guy who bragged to me about how he could change a windshield without removing it from the car!
      Regards, John McGraw
      • Ed Jennings
        The windshield assembly is relativly easy to remove from the car. Repalcing the glass is a whole new ballgame. If all youwant to do is remove the windshield for painting, there are very good instructions in the ST-12. You will need to remove the kick panels to access side fastners and probably remove the LH defroster duct. These steps are necessary on a 58-62, and I suspect the 57 is similar. The ST-12 says you have to remove the LH wiper transmission, but I never have had to on a late C1. The 57 could be different, never been under the dash in one. There are 12 total fastners, (4) 1/2" nuts, and (8) 3/8 or 7/16, can't remember which.
        • John S.
          • January 1, 1998
          • 81
          What is the ST-12?
          • John S.
            • January 1, 1998
            • 81
            Ed- Any hints I can get to replace the glass. I can find very little on restoring a 57. What is the proper procedure.???
            • Mike G.
              • April 30, 2001
              • 180
              ST-12 is the '53-'62 Corvette Service Guide, available from the NCRS bookstore (on this website) or any of the usual parts vendors. It's a "must have."
              Check the archives for loads of info on replacing the windshield. There have been numerous threads about it (including when I did mine) and even one in the last month or so. Also, e-mail me your mailing address and I'll send you an article from the June 2000 Vette magazine on the subject. I found it pretty useful.
              • Ed Jennings
                As Mike Green points out, the ST-12 is a must have. Go no further until you have one in hand. There is also a book by Noland Adams which many think is a must. I have never seen one, but it is alleged to be the "Bible". There is also a book published by Clymer titled somethingh like "Corvette V8 Owner's Guide" It is out of print, but there was a copy on eBay a couple of days ago. I see them there every so often. It is an excellent publication and covers some of the areas that the ST-12 refers you to the 61 passsenger car manual. Also excellent section on fuel injection.
                • Ed Jennings
                  Addendum
                  The Assembly Instruction Manual, AIM, is another valuable publication. These are available fronm the usual sources for around $20 and have assembly drawings for your specific model year. Another "must have" if you are going to do much with a vintage Vette.
