rear end pinion depth - NCRS Discussion Boards
  • Karl #35089
    If one were to replace the pinion bearings, keeping the existing gearset in the existing carrier with the existing shim(s), shouldn't the pinion depth return to its original correct value? Thanks, -Karl
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: rear end pinion depth
    Yes, it should, but it depends on the quality control of the replacement bearing.
