I am working on a very hard cranking passenger door window. I rebuilt the regulator, and it works perfectly. The window run that attaches to the outside end of the door is very tight against the window. The felt on the inside is worn somewhat and it is still too tight for the window to glide smoothly. It is a new GM part, number is 3723512, I bought about 20 years ago. It seems like the channel has less inside dimension than it should. Has anyone seen this before? Are the reproduction parts from Chicago Corvette any better?
Indy Meet Registration
