Fuel Line Replacement - NCRS Discussion Boards
  • Lee McGlamery
    Hi - Can the steel fuel line and vapor line on the right side of a 70 be replaced without dismantling the car? Looking at the AIM and the vehicle it looks as if there may be a couple of brackets that may be impossible to reach.
    Lee
  • Jeffrey S.
    • May 31, 1988
    • 1879
    Re: Fuel Line Replacement
    Lee:
    I replaced both the fuel lines (fuel and vapor return) and the brake lines on my 69 without reomoving the body. It is difficult but very do-able. The fuel line clips are hard to undo but with patience and the right tools (and attitude) you can do it. If you want a blow by blow descripton on how I did it I will be happy to ablige but to answer your queston, don't let anyone tell it can't be done.
    Hope this helps.
    Jeff
