I am ready to reinstall my rebuilt trailing arm assemblies. When I removed them I looked for the cotter pin for the shims, but there were none. After being assured that the cotter pins were present in late 70 cars I went back and looked again and sure enough I found the holes. Based on the position of the holes I can conclude that the only purpose of the cotter pin is to go through the "rear of the shims" to help hold them in position? Some shims have slots and others holes, do the slots just fit onto the cotter pin as well? Lastly what is the correct direction to insert the cotter pin, towards the inside or towards the outside and are both ends bent or just one, if one which one?
Thanks.
Thanks.
